Use edge devices to run on prem connector host
Run your On Prem Connector Host on an Edge IO.
The On-Prem Connector Host is a service that lives within your network that proxies trafic to the Tulip cloud for data that is not accessible to the broaded internet. More details on the OPCH are available here: Overview of On-Premise Connector Hosts
Running this on your Edge Device will significantly reduce your time to value, simplifying the infastructure required to run this service.
Preparation
First, make sure your:
  • Edge Device is fully set up and registered
  • OPC UA server or MQTT broker is set up
Creating Machine Data Source
  1. Head over to the Machine page on your Tulip account.
  1. On the Machine page, select the dropdown to locate the Machine Data Sources option.
  1. In the top right, select Create Connector.
You can fill out your OPC UA data as described in this article However, instead of running on the Cloud Connector Host; you can run on your Edge IO. The final configuration might look something like this:
Further Reading
