Set up an Edge IO
Purpose
How to set up an Edge IO for the first time
The Edge IO uses the same Edge Device Portal as the I/O Gateway and Edge MC. This article will outline how to connect the device.
Physical Setup
  1. Locate 24V power port
  2. Plug supplied power cable
  3. Plug the other end of the power cable into a power outlet
  4. Verify heartbeat LED (HRTBT) turns on and blinks
  1. Plug Ethernet cable into WAN port
  1. Plug the other end into an active Ethernet outlet and verify lights on the WAN port are blinking.
Next Steps
