Work with APIs
Get familiar with Tulip's APIs to access your Tulip data, generate content, and configure your instance.
Access Tulip's API documentation here.
For those unfamiliar with APIs, read Introduction to APIs.
When should you use an API?
You should use an API when you want to have an integration among Tulip and other software systems or access/change information in an App through a Connector, like creating a tulip table query or retrieving information about a station.
Tulip's API Documentation
Documentation Link Use Set Up
Table API Integrate external systems with Tulip Tables How to Set up a Tulip API
Operator API Create operators using an external system How to Use the Operator API
Machine Attributes API Send data to a specific attribute of a Machine How to use the Machine Attributes API
Stations API Manage and onboard new Stations How to Use the Stations API
