To ensure that your automation has failsafes in case you may have misconfigured your logic, we've implemented limits to protect any accidental issues.
Limit Details
The following limits to automations are per workspace:
| Limit | |
| Automation timeout | 60 second |
| Automation runs | 720 runs per minute 3600 runs per hour |
| Automation test runs | 360 test runs per hour |
| Actions on tables and connector functions (API Calls) | 1,200 executions per minute |
| Actions on connector functions (API Calls) | 1,200 executions per minute |
| Concurrent automation runs | Up to 10 automations are guaranteed to run at a time as of r283/LTS13, though the number can be higher. |
| Emails sent | Maximum 10 sent per minute |
| SMS sent | Maximum 10 messages sent per minute |
| Self-triggering automations (i.e. an automation that fires off of an "update table record" and updates that same table record) | 25 calls off of one triggering event. Read more here on how to mitigate this issue. |
| Variables per automation | 30 variables |
Limit Reached
Concurrent automation runs: If the limit is reached and another automation run begins, it will be queued, delayed, and attempted to re-run after a certain amount of time. After 10 re-attempts, the automation will be dropped from the queue and listed as limited.
All other limits: Runs that exceed any other limit in the table above stop immediately. They are not queued and are not retried.
Automation Example
For example, if I have eleven automations that responds to an "Add Table Record" event, one of those automations will have an automation run that responds with "limited".
