Manage Edge Devices
  • Updated on Jul 15, 2024
  • Published on Jul 15, 2024
How to Enable HTTPS on your Edge Device This is a walkthrough of how to enable HTTPS on your Edge Device Navigate to the device portal Turn on HTTPS certificate toggle. Upload your self-signed certificate and private key. ...
How to: Configure the Device Portal This is a walkthrough to configure your Edge Device Portal Timing Notice Beginning in OS58, users can de-activate their device portal. On the Edge device portal, users can disa...
  • Updated on Sep 30, 2022
How To Manage Gateways Within Tulip Here's how to view and update Edge Devices within Tulip. If you want to configure an individual Edge Devices , see this setup guide to learn how to log in to the Device Portal for each Device. After ...
  • Published on Jan 11, 2023
Learn what firmware versions Tulip supports for auto-updates for your release-type. Overview With Tulip's option to enable auto-updates for your Edge Devices , managing updates and staying on the most recent release is crucial to keeping your...
  • Updated on May 12, 2026
Learn how to configure settings for your Tulip Edge Devices via the Edge Device settings page. Tulip Edge Devices now auto-updates firmware to the newest supported version. We are introducting edge device auto-updates in order to: Keep dev...
  • Updated on Sep 21, 2023
Purpose Here are the different ways that you can configure Edge Devices to work with your company's network settings. This article explains how to configure your Edge Device to function properly on your network. NOTE ...
  • Published on Oct 26, 2022
Learn to configure the LAN Interface of a Tulip Edge Device. You can now configure the LAN interface of a Tulip Edge Device to act as an Upstream connection. By default, the LAN port will remain in the Downstream configuration. Note that the...
How Tulip Edge Devices Get Their IP Address A quick guide to the Tulip Edge Devices IP address policies. **The Tulip Edge MC and Edge IO devices have replaced the I/O Gateway device. Learn More The Tulip Edge Devices IP address de...
  • Updated on Sep 7, 2023
  • Published on Sep 13, 2022
Learn how to configure SNMP settings for Tulip's Edge Devices Beginning with OS 50.1, Tulip Edge Devices include an SNMP daemon for IT personnel to monitor the device on their network. Due to the large number of tools for interacting with SN...
  • Updated on Sep 20, 2022
How To Find Your Edge Device OS Version NOTE **Tulip I/O Gateway has been discontinued and replaced by Edge IO and Edge MC. Learn More This article explains how to check the version of Tulip OS that your Edge Devi...
  • Published on Jul 31, 2024
Learn how to use the HTTPS portal for edge devices. Starting with OS58, users can upload their own HTTPS termination certificates for the device portal. Enabling this functionality will disable the plain HTTP portal . Add the Certificate ...
