Learn how to write to machine attributes using OPC UA/MQTT protocols using Tulip
- How to create/edit a machine attribute that is writable?
- How to set a machine attribute using app triggers?
- Error/Warning Behaviours of Machine Attribute: Write
Set up
In order to set values to an attribute using OPC UA or MQTT protocol, you’ll need to set up a Machine and map it to a datasource so that you have data coming through. If you haven’t done this already, the following articles guide you through the process:
- How to Set up Your First Machine
- How to build your first MQTT data source
- How to build your first OPC UA Connector
Create/edit a machine attribute to be writable
Machine Attributes in Tulip can be used across different machines. They can be either read+write (writable) or read-only. Follow these steps to create or edit a writable attribute:
Create a Writable Attribute:
- Navigate to the Attributes List page.
- Click Create New Attribute.
- Enable the Write option and click Create.
Edit an Existing Attribute to Make it Writable
- Click the three dot menu next to the attribute and select Edit.
- Check the the Enable write option.
Write to a machine attribute using app triggers
You can write to a machine attribute in trigger logic, including on buttons, when a device fires, on timers, or on Step Level Triggers or App Level Triggers.
- In the trigger editor, add a new action.
- Select Write Machine Attribute from the drop-down list.
- Select Specific machine, variables, or machines at the desired station.
- Select the attribute you want to write to.
- Select the data value you want to write to.
In the above example: When a button is pressed, if the variable Speed is not blank, the trigger sets the Speed attribute for Mill #141 to the value of the Speed variable.
When selecting a variable or machine "at the station", all of the writable attributes will be listed.
⚠ Note: If the machine type at runtime does not include the selected writable attribute, the trigger will fail.
Machine Type Configuration Page
When configuring a Machine Type, writable attributes determined in the Attributes List page will be marked with a Write label.
Machine Datasources Configuration Page
You can only write to machine datasources that are OPC-UA or MQTT. The following datasources can't be written to and the triggers will fail:
- Edge Devices
- Edge IO
- Edge MC
- APIs
- Celos
- CelosX
A warning message will indicate unsupported configurations when applicable.
Change Writable Attributes to Read-Only
If a writable attribute is changed to read-only, any triggers using the Write Machine Attribute action will fail. This affects both Development Version and Published Versions of apps using the attribute.
Example Use Cases
Recipe Recalibration
- Dynamically update machine parameters to ensure precise configuration for each production run. You can save your good recipes and store them in a table, then use them again in the next run.
Process Control Integration
- Achieve a handshake between PLC/DCS and MES (Tulip) by writing sending start, stop or confirmation signals to your machine.
