- Print
Article summary
Did you find this summary helpful?
Thank you for your feedback!
Setting Up an Edge MC
How to set up Edge MC for the first time.
The Edge MC uses the same Device Portal as the Edge IO and I/O Gateway. This article will outline how to connect the device.
Physical Setup
- Locate DC-5V USB power port
- Plug supplied USB power supply
- Plug the other end of the power cable into a power outlet
- Verify red LED turns on and blinks
- Plug Ethernet cable into WAN port
- Plug the other end into an active Ethernet outlet
Next step:
Register your Edge MC to your Tulip account
Was this article helpful?
