Technical Specifications for Edge IO
Documentation for the Edge IO technical specifications
Certifications
  • FCC, CE, TELEC, and SRRC
Dimensions
  • 150mm x 130mm x 35mm
Weight
  • 250g
Power
  • 24V 2 Terminal, Non-locking Phoenix Contact Connector
Processor
  • ARMv8 4x A53 core
  • 8GB eMMC
  • 2 GB DDR3 RAM
RTC + Battery
USB-OTG “Type B” plug
Temperature Range (Operating / Storage)
  • 0 - 75 ℃ non-condensing
Software
  • Tulip Firmware
  • Node-RED
Industrial I/O
  • 4x 24V relay output drivers up to 500mA
  • 8x Industrial I/O for 5V to 36V digital input
Sensors and Instrumentation
  • 24V IEPE current source and input
  • -3V - 3V Differential Input
  • 0 - 10V Input
    • Optional: 24V power source
Peripherals
  • 6x USB 2.0
  • 1x 2-channel integrated Tulip Light Kit engine
Legacy
  • 1x RS232 with RTS/CTS
  • 1x RS485 half-duplex
Networking
  • 1x Gigabit Ethernet Phy (native) WAN
  • 1x 10/100 Ethernet Phy LAN
  • Dualband 802.11 ac Wireless Internet
  • LAN IP Range - 10.0.5.0/24
Security
  • ATECC608A
Trackable Assets
  • QR Code-based serial “tulip-mfg://EIO-01-XXXXXXXX”
  • Globally Unique MAC Addresses
DHCP Addresses
  • For dynamic addresses, 10.0.5.2-10.0.5.20 are available.
  • For static addresses, the entire 10.0.5.0/24 subnet is available which is 10.0.5.21-10.0.5.254.
