How to: Set up an MQTT Bridge
A setup guide on using Edge Device to read MQTT
Beginning with OS58, this functionality will be available for Edge devices.
In this article, you will learn the technical details of using MQTT read on Edge IO/MC.
Edge Devices support MQTT as well as OPC UA - read here for more.
Setting up your MQTT Bridge
To use your Edge Device as a MQTT Bridge, log into your Edge Device Portal.
Scroll down to "Service Configuration" and open "MQTT Bridge".
Hit the toggle to activate the MQTT bridge. Then, you can configure the details below. In addition, you can select whether you'd like to authenticate through a username and password or an API key.
