Machine Monitoring with Automations
Learn about how you can use automations to update machine data.
Automations capabilities for machine monitoring
You can perform the following actions in automations:
Write to machine activity fields directly
Automation trigger
When: Table record updated (Work Order ID field changes)
Action: Update Machine Activity Field "Program" = Work Order ID
Use the task Update data to write directly to machine attributes. You do not need connector functions.
Change machine state
Automation trigger
When: Machine attribute "Get Maintenance Mode" changes to "True"
Action: Update data: set machine state to "Maintenance"
Call connector functions
Automation trigger
When: machine attribute "Alarm Code" changes
Action: Call connector function "Send Slack Alert"
Parameters: Machine ID, Alarm Code, Timestamp
Create or update Tulip table records
Automation trigger
When: machine state changes to "Running"
Action: Create record in "Production Runs" table
Fields: Machine ID, Start Time, Work Order ID
Send notifications
Automation trigger
When machine downtime duration > 30 minutes
Action: Send email to "maintenance@company.com"
Subject: "Machine {Machine ID} down for 30+ minutes"
Limitations of automations for machine monitoring and their workarounds
1. Read machine attribute values directly
Limitation: Automations can only trigger on attribute changes and cannot fetch the current value
Workaround: Store the last known value in a Tulip table
Example
Automation trigger:
When "Machine Current" changes
Then: Store new value in table
With this method, the table always has the most recent value.
2. Access completion records**
Limitation: Automations do not have a trigger for app completions
Workaround: Use an app trigger on completion to write to a table, then create an automation on the table change
Further reading
