Machine monitoring troubleshooting
Learn how to troubleshoot common issues with machine monitoring.
Machine attribute not updating
Symptoms: Machine attribute shows "No Data" or stale timestamp
Root causes:
  1. OPC UA or MQTT connection lost
    • Navigate to Shop Floor > Machines > Machine Data Sources to view the Connector Host status
    • Click the Test button on the connector to test the connection
    • Verify network connectivity, including firewall rules and port forwarding
  2. Attribute not mapped correctly
    • Navigate to Machine > Configuration tab
    • Verify the attribute maps to the correct OPC UA node or MQTT topic
    • Click Get Latest Message (MQTT) or browse nodes (OPC UA) to verify the data source publishes
  3. Rate limit exceeded
    • Verify the total Hz across your instance does not exceed the 500 Hz limit
    • Reduce polling frequency or remove unnecessary attributes
Solution checklist
  • Connector Host shows "Connected" status
  • Machine attribute maps to an active data source
  • Data source publishes data (verify in Kepware or broker UI)
  • Machine is not in "Offline" state (verify in Machine Status widget)
Machine trigger not firing
Symptoms: Expected state change or activity field update does not occur
Root causes:
  1. Trigger condition never met
    • Example: Trigger specifies "When Machine Current > 10" but the attribute maximum is 8
    • Navigate to Machine > Activity tab to verify attribute values
  2. Trigger disabled
    • Navigate to Machine Type > Triggers and verify the toggle is ON
  3. Multiple conflicting triggers
    • Example: Trigger A sets the state to Running, and Trigger B immediately sets the state to Stopped
    • Review all triggers on the machine type for conflicts
  4. Trigger action references wrong machine
    • If using "at this station" in app triggers, verify the machine is assigned to the station
Solution checklist
  • Trigger is enabled (toggle ON)
  • Trigger condition is achievable (verify the attribute range)
  • No conflicting triggers exist
  • Station assignment is correct (if using "at this station")
OEE calculation incorrect
Symptoms: OEE percentage does not match expected values
Root causes:
  1. Incorrect state mapping
    • The "Running" state must be configured for the Availability calculation
    • Navigate to Machine Type > States and verify "Running" is marked as "uptime"
  2. Part count not incrementing
    • Verify the machine trigger writes to the "Part Count" activity field
    • View the Machine Activity table for part count values
  3. Ideal Run Rate not set
    • The Performance calculation requires an ideal run rate
    • Set the ideal run rate using the "Ideal Run Rate" machine activity field or an app input
  4. Clock skew
    • Machine timestamps are out of sync with the Tulip server
    • Verify timezone settings on the Connector Host and Tulip instance
Solution checklist
  • "Running" state is configured as uptime in Machine Type
  • Part Count activity field populates correctly
  • Ideal Run Rate is set (either static or dynamic)
  • Timezone alignment is verified
App not displaying machine data
Symptoms: Machine Status widget shows "No Machine Selected" or appears blank
Root causes:
  1. Machine variable not populated
    • If using a variable datasource, verify the variable is set at runtime
    • Add a text widget to display the variable value for debugging
  2. Station assignment missing
    • If using "at this station" logic, verify:
      • A station is selected in Player
      • The machine is assigned to that station
  3. Machine permissions
    • The user role may not have permission to view machine data
    • Navigate to Settings > Roles and verify the role has "Machine Monitoring" permissions
Solution checklist
  • Machine variable is populated (verify the variable value)
  • Station is selected in Player (if using "at this station")
  • Machine is assigned to the station (navigate to Shop Floor > Machines > Configuration)
  • User has Machine Monitoring permissions (navigate to Settings > Roles)
Automation tasks exceeding budget or rate limit
Symptoms: Unexpected automation costs due to high task execution volume
Root causes:
  1. Trigger fires too frequently
    • Example: An automation on "Every time machine attribute changes"
    • If the attribute updates at 1 Hz, that results in 3600 tasks/hour per machine
  2. Missing conditional filters
    • The automation runs even when not needed
    • Add a condition: "Only when attribute value > threshold"
  3. Redundant automations
    • Multiple automations perform similar tasks
Solutions
  1. Batch operations
Before:
Automation: When machine attribute changes → Write to table
(Executes 3600 times/hour)
After:
Machine Trigger: When attribute changes → Update activity field
Automation: Every 1 hour → Copy activity field to table
(Executes 1 time/hour)
  1. Add conditional filters
Before:
Automation: When machine state changes → Send notification
(Executes on every state change, even Running → Running)
After:
Automation: When machine state changes AND new state = "Stopped" → Send notification
(Executes only on Stopped state)
  1. Use machine triggers for eligible tasks
  • If the task only updates machine state or activity fields, use a machine trigger (free)
  • Reserve automations for table writes, connector calls, and notifications
Further reading
