Login
About Us
API Documentation
Glossary
English
English
Chinese
French
German
Italian
Ja - 日本語
Polish
Spanish
Русский
Portuguese
Hungarian
Korean
Contents
x
Get Started
Build
Run Apps
Deploy and Manage
Developer Tools
IT and Technical Docs
Guides
Library
Release Announcements
Powered by
Production Management Solutions
4 Articles
in this category
Contributors
Share this
Print
Share
Contents
4 Articles
in this category
Written by
Lianna Churchill
Share
Digital Traveler Use Case
Imagine you’re an industrial engineer responsible for improving an assembly process. Your supervisor tasks you with decreasing cycle time. After overseeing several orders, you note that operators are spending a significant amount of time filling ou...
Written by
Lianna Churchill
Updated on : 12 Jan 2024
Performance Visibility Use Case
Imagine you’re a plant manager at a medium-sized company. There are multiple operations for production that produce various items and while the company is doing well, you know there are areas for improvement. There is a high scrap rate, excessive d...
Written by
Lianna Churchill
Updated on : 01 Dec 2023
Production Tracking Use Case
Imagine you’re a production supervisor at a large company whose operations tend to stall at different points in a process. The inefficiencies lead to missing on-time deliveries and production targets. You’re currently tracking cycle time and first ...
Written by
Lianna Churchill
Updated on : 21 Dec 2023
Daily Management Board Use Case
Imagine you’re a production lead at a company that has limited visibility into daily operations. You’ve been compiling metrics into a daily management dashboard, but it takes time to source the data then manually calculate numbers to write down. Op...
Written by
Lianna Churchill
Updated on : 24 May 2024
