--- title: "Platform limits and best practices" slug: "platform-limits-and-best-practices" tags: ["Limits", "Best Practices"] updated: 2026-03-30T18:32:23Z published: 2026-03-30T18:32:23Z canonical: "support.tulip.co/platform-limits-and-best-practices" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Platform limits and best practices *Links to articles that include various platform limits and best practices.* ## Apps ### App design and architecture - [Asset naming best practices](https://support.tulip.co/docs/best-practices-for-naming-elements-in-tulip) - [App design best practices](https://support.tulip.co/docs/app-design-best-practices) - [GxP app building best practices](https://support.tulip.co/docs/best-practices-for-gxp-app-building) ### Triggers - [Trigger limits and timeouts](/r230/docs/triggers#limits-and-timeouts) - [Trigger best practices](/r230/docs/triggers#best-practices) - [Table API and timer trigger action best practices](/r230/docs/best-practices-for-high-performance-apps) - [Capture app screenshot best practices](https://support.tulip.co/docs/capture-app-screenshot#best-practices) - [Send SMS limits](https://support.tulip.co/docs/setup-sms-notifications-for-tulip-users#limits) ### Widgets - [Conditional formatting limits](https://support.tulip.co/docs/conditional-formatting#limits) - [Conditional formatting best practices](https://support.tulip.co/docs/conditional-formatting#troubleshooting-and-best-practices) - [Machine widget data point limits](https://support.tulip.co/docs/add-a-machine-widget-to-an-app#machine-timeline) ### App management - [Apps and app folders limits](https://support.tulip.co/docs/add-and-manage-apps#limits-on-apps-and-app-folders) --- ## Automations - [Automations limits](/r230/docs/automation-limits) --- ## Functions - [Functions limits](/r230/docs/functions#limits) --- ## Data - [Data type limits and formats](/r230/docs/data-types) - [Numeric precision limits](https://support.tulip.co/docs/numbers-and-numeric-precision#limits-and-outofbounds-behavior) - [Data storage best practices](/r230/docs/best-practices-for-storing-data) **Tables** - [Table rate limits](/r230/docs/rate-limiting#table-rate-limits) - [Table field limits](https://support.tulip.co/docs/tables#fields) - [Spreadsheet import limits](https://support.tulip.co/docs/import-a-spreadsheet-into-a-table#limits) - [Table query limits](https://support.tulip.co/docs/table-queries-and-aggregations#limits) - [Table aggregation limits](https://support.tulip.co/docs/table-queries-and-aggregations#limits1) **Completions** - [Completion records best practices](https://support.tulip.co/docs/completions#limitations-and-best-practices) --- ## Shop Floor - [Shop floor management limits](/r230/docs/shop-floor-management#shop-floor-management-limits) --- ## Analytics - [Analytics limits](/r230/docs/analytics#limits) --- ## Connectors - [Connectors and connector functions limits](/r230/docs/connector-limits) - [Connector host security practices for external servers](https://support.tulip.co/docs/connector-hosts#what-are-the-security-issues-of-opening-access-to-my-db-api-or-opc-ua-server-to-the-tulip-cloud-connector-host) - [System integration best practices](https://support.tulip.co/docs/build-your-first-system-integration#best-practices) - [Connector input encoding control](/r230/docs/connector-input-encoding-control) --- ## Machines - [Machines / ingestion limits](/r230/docs/add-and-configure-machines#ingestion-limits) - [Other machine limits](https://support.tulip.co/r230/docs/add-and-configure-machines#other-machine-limits) --- ## AI actions Limits per each Tulip AI action: - [Answer question from data/document trigger actions](/r230/docs/answer-question-from-input#limits) - [Speech-to-text Input](/r230/docs/speech-to-text-input#limits) - [Classify trigger action](/r230/docs/classify-trigger-action#limits) - [Chat with tables](/r230/docs/chat-with-tables#limits) - [Translate](/r230/docs/translate#limits) - [Extract text](/r230/docs/extract-text#limits) --- ## Import/Export - [Import/Export limits](https://support.tulip.co/docs/export-import#limits) --- ## Users - [Limits on user management](https://support.tulip.co/r230/docs/user-management#user-management-limits) --- ## Workspaces - [Limits on workspaces](/r230/docs/workspace-management#limits) --- ## Asset Upload - [File upload limits](https://support.tulip.co/docs/upload-a-file#file-upload-limits) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have solved a similar topic!
