--- title: "Factory Kit quickstart guide" slug: "factory-kit-quickstart-guide" tags: ["edge Connectivity", "Factory Kit", "Getting started"] updated: 2022-09-30T17:26:28Z published: 2022-09-30T17:26:28Z canonical: "support.tulip.co/factory-kit-quickstart-guide" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Factory Kit quickstart guide ## Factory Kit Quickstart Guide *Here's everything you need to know about setting up your Factory Kit.* #### The Tulip Factory Kit was the first-touch kit of accessories and hardware for new Tulip users to get started with edge connectivity. #### **Factory Kit is discontinued as of June 23, 2022.** Hooray! You’ve just received your Factory Kit. Now, let’s get it up and running. Your factory kit is just a small example of the different ways Tulip Edge hardware can enable your factory. If you have a use-case in mind and you just wanna hit the ground running, check out this [Edge IO Overview,](https://support.tulip.co/docs/edge-io-overview) it walks through all the great resources for Tulip Edge Devices. ## **If you want a step-by-step guide on testing all of your factory kit hardware, continue on!** Please go ahead and download Factory Kit Unit Tests from our [Library](https://tulip.co/library/suites/factory-kit-unit-tests/) in order to be able to follow along and test whether the devices are functioning correctly. These are the articles we will be working through. First, 2 documents that walk you through setting up your Edge IO: 1. [Setting up an Edge IO](https://support.tulip.co/docs/setting-up-an-edge-io) [Required] 2. [Registering an Edge IO](https://support.tulip.co/docs/how-to-register-an-edge-io) [Required] The rest of the factory kit articles are optional, feel free to do any/all of them: 1. [Connecting the Factory Kit USB devices](https://support.tulip.co/docs/connecting-the-factory-kit-usb-devices-barcode-foot-pedal-temphumidity) [Optional] 2. [Edge IO Light Strip Setup](https://support.tulip.co/docs/edge-io-light-strip-setup) [Optional] 3. [Setting up the Break Beam Sensor](https://support.tulip.co/docs/setting-up-the-break-beam-sensor) [Optional] 4. [Assembling the Andon Light stack](https://support.tulip.co/docs/assembling-the-light-stack) [Optional] Each Factory Kit comes with the following items: - Tulip Edge IO - 24V Power Supply - 3 Foot Ethernet Cable - 2 light strips - Barcode scanner - Foot pedal - Temperature/humidity sensors - Break beam - Light stack kit ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Factory%20Kit%20Quickstart%20Guide_467197117.png) The next few articles will walk you through the initial setup of your Factory Kit. Let’s start with the Edge IO - [Setting Up an Edge IO](https://support.tulip.co/docs/setting-up-an-edge-io)
