--- title: "Add and manage users" slug: "add-and-manage-users" tags: ["Account Management", "User Role", "User"] status: "update" updated: 2026-10-30T18:35:40Z published: 2026-10-30T18:35:40Z canonical: "support.tulip.co/add-and-manage-users" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Add and manage users *Learn how to add users to Tulip and about the available roles* To manage users you must be an Account Owner. To view users on your instance, click on your profile icon in the top right and select either **Account Settings** or **Workspace Settings** (depending on your plan). Tulip Instances can have a **maximum of 10,000 users**. NOTE: If Tulip is integrated with your [single sign on](/r230/docs/authorization-and-access-control-using-saml) (SSO), new user accounts are not able to be created in Tulip and are instead created when logging in as a valid SSO user. ## Add New Tulip Users Only Account Owners, or users with custom user management permissions, can add new users. Select **Users** in your **Settings** page, and press the **Add User** button. ### Add an Operator 1. Fill in the Operator’s full name. 2. Fill in the Badge ID number. 3. Press **Create User**. From release r235, users can add an optional email address to existing Operator roles. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_575758980.png) This will enable Operator roles to upgrade to higher roles as and when needed. ### Add any other user role 1. Fill in the user’s full name 2. Fill in the user's email address 3. Fill in the user’s Badge ID number 4. Select the role for this new user ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_376160714.png) NOTE: Once a new user is added to a Tulip account, an email will be automatically sent to the user prompting the individual to create a new profile. **Operators without an email address will not receive an email, and can begin using the Tulip Player immediately.** Operators with an email address receive a confirmation email. ### Users with "System Administrator" Roles Tulip employees may access your instance in a support capacity. These users will appear as users with the "System Administrator" role. They can be managed in the same way as any other user. ## View Full Permissions of User Roles Tulip uses the following terminology to describe roles: - **Full Access** - Able to create, view, edit and archive the listed asset - **Limited Access** - Able to use the asset in the specific ways determined by checked boxes in the UI - **View Only** - Only able to view the asset - **Cannot View** - Unable to view the asset To view the permissions for each role, go to the **Users** page in **Account Settings**. Click the **Roles** tab. ![Users Roles Page with Role Details](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Users%20Roles%20Page%20with%20Role%20Details.png) Select a role to view the full permission details ## Edit User Details Only Account Owners can edit user account details. To do this select the user you wish to modify. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_194065639.png) On the user's detailed page, you can edit the following fields: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_194066018.png) - Profile Picture - Name - Badge ID - Language - Role - Workspace (if enabled) ## Adding a Phone Number A phone number can be added to a user account in Tulip but only by the user themselves. 1. Click on **profile icon** in the top right corner 2. Select **My Profile**. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_91668245.png) 1. Click on the **Add phone number...** ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_194062345.png) 1. A modal will pop up prompting for the phone number and once entered, click **Send Verification Code**. Enter the code received, click **Verify** and if successful, **Done**. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_194062553.png) You can also remove a user's phone number from the same screen. ## Resend User Invitations For security purposes, invitation and email confirmation links to Tulip expire after 72 hours. If an invited user does not accept the invite within that period, they will see a message like this when they try to log in: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Adding%20Users%20and%20Managing%20User%20Roles_511527365.png) To fix this problem, you need to resend their welcome link. In the **Users** page in **Account Settings**, find the user who requires a new invitation link. A message saying "Invite expired" should be present with the option to "Resend". Hovering over the "Invite expired" message will display the date and time of the previous invite. Click **Resend** to send the user's welcome email again. You can resend an invitation once every five minutes. If they still are unable to log in, please contact [support@tulip.co](mailto:support@tulip.co) for more help. ### Email verification link already used Email verification links can only be used once. If a user opens the link a second time, or refreshes the page, they will see an **"Email change/verification failed"** page, even if the first visit succeeded. This message appears when: - The link was already used. If the first visit succeeded, no action is needed. The user can sign in with their verified email. - The user does not exist or has been deactivated. ![Image](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/image-2ZJTQUOC.png) ## Deactivate a User NOTE: The only users who can deactivate users are Account Owners or [users with custom roles](/r230/docs/customize-user-roles) that grant user management permissions. You can choose to deactivate users to preserve the history of an individual user’s actions within Tulip. The user account can always be reactivated later. You can deactivate a user in the following steps: 1. Click on your **user icon** in the top right of navigation bar and click **Settings** 2. Select **Users** from the panel on the left side. 3. Select the User you wish to deactivate, then, click the **three-dot-menu** button. The following modal will appear: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Deactivate_Delete%20Users%20and%20Operators_86459935.png) 1. Click **Deactivate** to confirm. A deactivated user cannot log in. Deactivated users will not appear on any lists of users within the Tulip App Editor. When a user is deactivated, they lose all permissions. ### View Deactivated Users You can see all deactivated users in the **Users list**, using the **Status** filter to view **Deactivated** users. By default, you will not see deactivated users in the **Users list**. ![Users List Status Filter - Deactivated](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Users%20List%20Status%20Filter%20-%20Deactivated.png) ## Reactivate a User An Account Owner, or user with custom user management permissions, can also reactivate a user. To reactivate a user, use the following steps: 1. View deactivated users by clicking the **Status** filter and selecting **Deactivated**. 2. Select the deactivated user’s name. Click the **three-dot-menu** in the top right corner and click **Reactivate User**. ![Reactivate User](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Reactivate%20User.gif) When the user was originally deactivated, their badge ID became available. If the deactivated user’s badge ID was “1234”, another user can start using that badge ID before the deactivated user is reactivated. If this is the case and you want to reactivate the original user that claimed “1234”, you can do one of the following: - Change the active user of “1234” to a different badge ID. Then, you can reactivate the original holder of “1234”. - Give the reactivated user a new badge ID in the "Username" field. ## Further Reading - [Updating Fields On Users from App Logic](https://support.tulip.co/docs/how-to-update-fields-on-individual-tulip-users-and-operators-from-apps) - [Authorization and Access Control Using SAML](/r230/docs/authorization-and-access-control-using-saml) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have faced a similar question! **Tulip Instance** A Tulip customer account. Your instance can be found at https://[your-instance].tulip.co When *your instance* is referenced, we are just talking about your Tulip account on an organization-level, not user-level. **Tulip Player** **Tulip Player** is the Windows/Mac executable program where users can run Tulip apps. Tulip player allows you to create a more seamless user experience by removing the need for a web browser and allows increased IT controls. **App Editor** The web interface used for building applications. Where you design a user interface, add logic, and connect your applications to **Tables**. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Screen%20Shot%202022-09-13%20at%207.50.23%20AM.png)
