--- title: "Use Serial with Edge IO" slug: "use-serial-with-edge-io" tags: ["Serial", "Edge IO", "Node-RED"] updated: 2022-09-30T18:14:22Z published: 2022-09-30T18:14:22Z canonical: "support.tulip.co/use-serial-with-edge-io" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Use Serial with Edge IO ## How to: Use Serial with Edge IO *A setup guide on using Serial with Edge IO* In this article, you will learn the technical details of using serial on Edge IO. Edge IO supports serial connections over USB, RS-232, or RS-485. This article will cover the hardware connections and software identifiers for each connection. To learn how to communicate this serial data to Tulip, please see our other support articles: **[Guide on Generic Serial Driver](https://support.tulip.co/docs/how-to-use-the-generic-serial-driver-on-io-gateway) **[Guide on Node-RED setup with Serial](https://support.tulip.co/docs/how-to-use-serial-with-node-red-1) ## Connect using USB To use serial over USB, you will need a serial device that connects over USB, or a serial-to-USB adapter (for example, a RS232-to-USB adapter cable, or RS485-to-USB adapter). The Edge IO has six USB ports; you can plug your USB cable into any USB port. While plugging into USB, the identifiers will be assigned in order of being plugged in: - 1st USB port plugged in: `/dev/ttyUSB0` - 2nd USB port plugged in: `/dev/ttyUSB1` - 3rd USB port plugged in: `/dev/ttyUSB2` #### **`...`** ## Connect using RS-232/RS-485 The Edge IO also has RS-232 and RS-485 ports. The identifier for the serial device: - RS-232: `/dev/ttyS1` - RS-485: `/dev/ttyS2` *Note: RS-232 uses a standard DB9 connector, and supports RTS/CTS, but not DCD/DTR/DSR. RS-485 is half-duplex.* #### Edge IO Port Diagram: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%3A%20Use%20Serial%20with%20Edge%20IO_456206497.png) ![How to: Use Serial with Edge IO](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%3A%20Use%20Serial%20with%20Edge%20IO_458551354.png) *See above the RS-232 and RS-485 pinouts.*
