Tulip Light Kit Technical Specifications
Here are all the details about the Tulip Light Kit's technical specs.
Voltage supply, Current Consumption and Conditioning
- Rated supply voltage: 5V (Vin_min: 4.8V Vin_max: 5.5V)
- Rated supply current: 4A (I_max is 0.4A per channel)
- Nominal power consumption: 5W (2 LED strips fully illuminated)
- IC: LTC4360
Temperature Range (Operating / Storage)
- 0 - 75 ℃
Humidity
- 5% - 80% rel hum. non-condensing
OS/Software
- Connect this device to a Tulip I/O Gateway
- Configure the device using Tulip Apps
LED Outputs
- 8 Channel outputs
- RGB Leds
- LED IC: WS2812b
Mechanical
- 160mm x 100mm x 31mm (6.3 in x 4.0 in x 1.2 in)
- Weight: 280g (0.62 lbs)
- Aluminum (Anodized)
- Mounting: 35mm DIN Mount Compatible
