Edge MC technical specifications
Technical Specifications for Edge MC
Edge MCProduct Specifications
Dimensions
  • 63mm x 56mm x 35mm
Weight
  • 10g
Power
  • 5V / 2.5A USB Micro, 120V/240V (MFG P/N: SMI10-5-V-I38 included)
Processor
  • CPU: Allwinner H3 SoC (Quad A7)
  • Storage: 8GB eMMC
  • RAM: 1GB
RTC + battery
2048 byte PROM
Software
  • Tulip Firmware
  • Node-RED
Peripherals
  • 2x USB 2.0
Networking
  • 1x 1GB/s Ethernet Phy WAN
  • 1x 10/100 MB/s Ethernet Phy LAN
  • Dual Band 802.11 b/g/n Wireless (supports concurrent AP/Station modes)
  • LAN IP Range - 10.0.5.0/24
Legacy
  • 1x 5V TTL UART with TX/RX (no RTS/CTS)
LEDS
  • 2x Green LEDs
  • 1x Red LEDs
  • 4x Link + Speed LEDs for 2x Ethernet
Trackable Assets
  • QR Code based serial “tulip-mfg://EMC-01-XXXXXXXX”
  • MAC addresses
Certifications
  • FCC
  • CE
  • CE-RED
DHCP Addresses
  • For dynamic addresses, 10.0.5.2-10.0.5.20 are available.
  • For static addresses, the entire 10.0.5.0/24 subnet is available which is 10.0.5.21-10.0.5.254.
