--- title: "Set up wireless connection on Edge MC" slug: "set-up-wireless-connection-on-edge-mc" tags: ["Edge MC", "Edge", "Kado Portal", "Kado"] updated: 2022-09-20T21:03:20Z published: 2022-09-20T21:03:20Z canonical: "support.tulip.co/set-up-wireless-connection-on-edge-mc" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Set up wireless connection on Edge MC ## How to Setup Wireless Connection on Edge MC *Enable WiFi on Edge MC* To set up a wireless-only connection on Edge MC, make sure you have first [set up your hardware](https://support.tulip.co/docs/setting-up-an-edge-mc) First, log into the Device Portal on your Edge MC's access point. From here, you can collapse the Wired connection tab, or scroll down to the Wireless Connection tab. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Setup%20Wireless%20Connection%20on%20Edge%20MC_232264801.png) Ensure that the WiFi is set to enabled, then select your network from the dropdown. Upon selection, you will be prompted to fill out the network's password. It will look something like this. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Setup%20Wireless%20Connection%20on%20Edge%20MC_232265240.png) At the bottom of the page, press Save. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Setup%20Wireless%20Connection%20on%20Edge%20MC_232267287.png) Once saved, the circle next to the Wireless dropdown should become green after recognizing the network. Now your Edge MC can run entirely over WiFi, and will not require a wired connection. **Device Portal** The **Device Portal** is the home where you can configure **Light Kits** and Edge Drivers, see **Edge Device** network status, and more. **Edge IO** **Edge MC** is a Tulip-developed **Edge Device**. run **Node-RED** flows on dedicated hardware with built-in security and stability. **Edge Mc** can also act as a **Connector Host** or OPC-UA Broker
