--- title: "Set up an MQTT bridge on an Edge Device" slug: "set-up-an-mqtt-bridge-on-an-edge-device" updated: 2024-07-15T18:25:27Z published: 2024-07-15T18:25:27Z canonical: "support.tulip.co/set-up-an-mqtt-bridge-on-an-edge-device" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Set up an MQTT bridge on an Edge Device ## How to: Set up an MQTT Bridge *A setup guide on using Edge Device to read MQTT* MQTT Broker Beginning with OS58, this functionality will be available for Edge devices. In this article, you will learn the technical details of using MQTT read on Edge IO/MC. Edge Devices support MQTT as well as OPC UA - [read here for more](https://support.tulip.co/docs/using-edge-mc-to-run-opc-ua-1). ## Setting up your MQTT Bridge To use your Edge Device as a MQTT Bridge, log into your Edge Device Portal. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Enable%20and%20Set%20Up%20the%20Edge%20Device%20MQTT%20Broker_566761938.png) Scroll down to "Service Configuration" and open "MQTT Bridge". ![Screenshot 2024-07-15 at 1.44.04 PM.png](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Screenshot%202024-07-15%20at%201.44.04%20PM.png) Hit the toggle to activate the MQTT bridge. Then, you can configure the details below. In addition, you can select whether you'd like to authenticate through a username and password or an API key.
