--- title: "Reset Edge MC to factory settings" slug: "reset-edge-mc-to-factory-settings" tags: ["Edge", "Edge MC", "Kado Portal", "Kado", "edge Connectivity", "Edge Device", "Hardware"] updated: 2022-09-18T02:12:02Z published: 2022-09-18T02:12:02Z canonical: "support.tulip.co/reset-edge-mc-to-factory-settings" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Reset Edge MC to factory settings ## Reset Edge MC to Factory Settings *Forget your Edge MC password?* In the event of a forgotten Edge MC Password, or other need to restore to factory settings, reset the Edge MC as follows. This will reset the Edge MC to its default configuration by purging: - Network Configurations - Edge MC Access Credentials - Tulip Account Authentication - Driver Configurations NOTE The Edge MC's IP address may also change after a factory reset. This is the only way to reset your Edge MC's password: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Reset%20Edge%20MC%20to%20Factory%20Settings_206512528.png) 1. Verify the Edge MC is not actively controlling any devices 2. Hold down RST button for 10 seconds, green LEDs should flash **Note: Please be careful when clicking the RST button** 3. Release button when blinking red LED (L3) turns off 4. When red LED turns back on (around 60 seconds), Edge MC is reset. 5. Set up the Edge MC **Edge IO** **Edge MC** is a Tulip-developed **Edge Device**. run **Node-RED** flows on dedicated hardware with built-in security and stability. **Edge Mc** can also act as a **Connector Host** or OPC-UA Broker
