--- title: "Reset Edge IO to factory settings" slug: "reset-edge-io-to-factory-settings" tags: ["Edge", "Edge IO", "Hardware", "Edge Devices Page", "Kado Portal", "Kado", "edge Connectivity", "Edge Device"] updated: 2022-09-20T21:00:33Z published: 2022-09-20T21:00:33Z canonical: "support.tulip.co/reset-edge-io-to-factory-settings" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Reset Edge IO to factory settings ## Reset Edge IO to Factory Settings *Instructions to reset your Edge IO to factory settings* In the event of a forgotten Edge IO Password, or other need to restore to factory settings, follow the steps below to reset the Edge IO. This will reset the Edge IO to its default configuration by purging: - Network Configurations - Edge IO Access Credentials - Tulip Account Authentication - Driver Configurations - Node-RED Flows and Configuration NOTE The Edge IO’s IP address may also change after a factory reset. A factory reset is the only way to reset your Edge IO’s password: 1. Verify the Edge IO is not actively controlling any devices 2. Hold down the A and B buttons simultaneously for 5 seconds. The heartbeat LED (HRTBT) will stop flashing. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Reset%20Edge%20IO%20to%20Factory%20Settings_403314869.png) 1. Release buttons. The device will now reboot 2. When the heartbeat LED turns back on, the Edge IO has completed the reset process. 3. [Set up the Edge IO](https://support.tulip.co/docs/setting-up-an-edge-io) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have faced a similar question! **Edge IO** **Edge IO** is a Tulip-developed **Edge Device**. Interface with digital inputs directly from **Triggers**, flip digital outputs, run **Node-RED** flows, and more! **Edge IO** can also act as a **Connector Host** or OPC-UA Broker
