--- title: "Manage drivers for an interface" slug: "manage-drivers-for-an-interface" tags: ["Devices", "Shop Floor", "Display Device", "Display Devices Page", "Driver"] updated: 2024-07-09T18:11:43Z published: 2024-07-09T18:11:43Z canonical: "support.tulip.co/manage-drivers-for-an-interface" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Manage drivers for an interface *Learn how to manage drivers for a given interface (display device) on your shop floor.* Feature update From r283 onwards, display devices are renamed interfaces. ## Why do I need to manage Drivers? Drivers are small pieces of code included in your Tulip Player that allow the interface (display device) running apps on Player to communicate with 3rd party devices such as barcode scanners, foot pedals, cameras, and much more. A driver needs to be "enabled" to allow the app on Player to communicate with a 3rd party device. It is necessary to configure your Player to only enable drivers for devices that you are currently using in order to preserve performance. ## Configure Drivers from the Factory Shop Floor To configure drivers for a specific Player, open the Factory instance that the Player is connected. 1. In the **Shop Floor** tab dropdown, click **Stations**. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275219911.png) 1. Seelct the active interface. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275225469.png) 1. Click **Configure Drivers**. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275221195.png) 1. From the Driver Configuration page, select the drivers you wish to either enable or disable. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275221366.png) Toggle the switch right on turn the driver on or left to turn it off. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275221782.png) 1. Click **Save** to confirm your configuration and to send these changes to the Player. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275225275.png) 1. On Player, click **Confirm** on the **Reload App?** pop-up to propagate the changes that enabling the driver(s) could have on the running app. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275225642.png) While most drivers on Player can only be turned on and off, some drivers have more advanced configuration options. One specific example is the “USB-BARCODE” driver, which allows you to add and remove custom devices to be associated with the driver itself. Here is an example of a barcode scanner being added to the “USB-BARCODE” driver configuration with a name, a product ID (PID) number, and a vendor ID (VID) number: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Manage%20Drivers%20for%20a%20Display%20Device_275225870.png)
