--- title: "Machine Monitoring with Automations" slug: "machine-monitoring-with-automations" updated: 2025-12-19T21:42:05Z published: 2025-12-19T21:42:05Z canonical: "support.tulip.co/machine-monitoring-with-automations" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Machine Monitoring with Automations *Learn about how you can use automations to update machine data.* ## Automations capabilities for machine monitoring You can perform the following actions in automations: ### Write to machine activity fields directly #### Automation trigger **When**: Table record updated (Work Order ID field changes) **Action**: Update Machine Activity Field "Program" = Work Order ID Use the task **Update data** to write directly to machine attributes. You do not need connector functions. ### Change machine state #### Automation trigger **When**: Machine attribute "Get Maintenance Mode" changes to "True" **Action**: Update data: set machine state to "Maintenance" ### Call connector functions #### Automation trigger **When**: machine attribute "Alarm Code" changes **Action**: Call connector function "Send Slack Alert" **Parameters**: Machine ID, Alarm Code, Timestamp ### Create or update Tulip table records #### Automation trigger **When**: machine state changes to "Running" **Action**: Create record in "Production Runs" table **Fields**: Machine ID, Start Time, Work Order ID ### Send notifications #### Automation trigger **When** machine downtime duration > 30 minutes **Action**: Send email to "maintenance@company.com" **Subject**: "Machine {Machine ID} down for 30+ minutes" ## Limitations of automations for machine monitoring and their workarounds ### 1. Read machine attribute values directly **Limitation**: Automations can only trigger on attribute changes and cannot fetch the current value **Workaround**: Store the last known value in a Tulip table **Example** Automation trigger: **When** "Machine Current" changes **Then**: Store new value in table With this method, the table always has the most recent value. ### 2. Access completion records** **Limitation**: Automations do not have a trigger for app completions **Workaround**: Use an app trigger on completion to write to a table, then create an automation on the table change ## Further reading - [Automations](/r230/docs/automations-1) - [Automation limits](/r230/docs/automation-limits) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have solved a similar topic!
