--- title: "Machine monitoring troubleshooting" slug: "machine-monitoring-troubleshooting" updated: 2025-12-19T21:38:48Z published: 2025-12-19T21:38:48Z canonical: "support.tulip.co/machine-monitoring-troubleshooting" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Machine monitoring troubleshooting *Learn how to troubleshoot common issues with machine monitoring.* ## Machine attribute not updating **Symptoms**: Machine attribute shows "No Data" or stale timestamp **Root causes**: 1. **OPC UA or MQTT connection lost** - Navigate to Shop Floor > Machines > Machine Data Sources to view the Connector Host status - Click the Test button on the connector to test the connection - Verify network connectivity, including firewall rules and port forwarding 2. **Attribute not mapped correctly** - Navigate to Machine > Configuration tab - Verify the attribute maps to the correct OPC UA node or MQTT topic - Click Get Latest Message (MQTT) or browse nodes (OPC UA) to verify the data source publishes 3. **Rate limit exceeded** - Verify the total Hz across your instance does not exceed the 500 Hz limit - Reduce polling frequency or remove unnecessary attributes ### Solution checklist - Connector Host shows "Connected" status - Machine attribute maps to an active data source - Data source publishes data (verify in Kepware or broker UI) - Machine is not in "Offline" state (verify in Machine Status widget) ## Machine trigger not firing **Symptoms**: Expected state change or activity field update does not occur **Root causes**: 1. **Trigger condition never met** - Example: Trigger specifies "When Machine Current > 10" but the attribute maximum is 8 - Navigate to Machine > Activity tab to verify attribute values 2. **Trigger disabled** - Navigate to Machine Type > Triggers and verify the toggle is ON 3. **Multiple conflicting triggers** - Example: Trigger A sets the state to Running, and Trigger B immediately sets the state to Stopped - Review all triggers on the machine type for conflicts 4. **Trigger action references wrong machine** - If using "at this station" in app triggers, verify the machine is assigned to the station ### Solution checklist - Trigger is enabled (toggle ON) - Trigger condition is achievable (verify the attribute range) - No conflicting triggers exist - Station assignment is correct (if using "at this station") ## OEE calculation incorrect **Symptoms**: OEE percentage does not match expected values **Root causes**: 1. **Incorrect state mapping** - The "Running" state must be configured for the Availability calculation - Navigate to Machine Type > States and verify "Running" is marked as "uptime" 2. **Part count not incrementing** - Verify the machine trigger writes to the "Part Count" activity field - View the Machine Activity table for part count values 3. **Ideal Run Rate not set** - The Performance calculation requires an ideal run rate - Set the ideal run rate using the "Ideal Run Rate" machine activity field or an app input 4. **Clock skew** - Machine timestamps are out of sync with the Tulip server - Verify timezone settings on the Connector Host and Tulip instance ### Solution checklist - "Running" state is configured as uptime in Machine Type - Part Count activity field populates correctly - Ideal Run Rate is set (either static or dynamic) - Timezone alignment is verified ## App not displaying machine data **Symptoms**: Machine Status widget shows "No Machine Selected" or appears blank **Root causes**: 1. **Machine variable not populated** - If using a variable datasource, verify the variable is set at runtime - Add a text widget to display the variable value for debugging 2. **Station assignment missing** - If using "at this station" logic, verify: - A station is selected in Player - The machine is assigned to that station 3. **Machine permissions** - The user role may not have permission to view machine data - Navigate to Settings > Roles and verify the role has "Machine Monitoring" permissions ### Solution checklist - Machine variable is populated (verify the variable value) - Station is selected in Player (if using "at this station") - Machine is assigned to the station (navigate to Shop Floor > Machines > Configuration) - User has Machine Monitoring permissions (navigate to Settings > Roles) ## Automation tasks exceeding budget or rate limit **Symptoms**: Unexpected automation costs due to high task execution volume **Root causes**: 1. **Trigger fires too frequently** - Example: An automation on "Every time machine attribute changes" - If the attribute updates at 1 Hz, that results in 3600 tasks/hour per machine 2. **Missing conditional filters** - The automation runs even when not needed - Add a condition: "Only when attribute value > threshold" 3. **Redundant automations** - Multiple automations perform similar tasks ### Solutions 1. **Batch operations** Before: Automation: When machine attribute changes → Write to table (Executes 3600 times/hour) After: Machine Trigger: When attribute changes → Update activity field Automation: Every 1 hour → Copy activity field to table (Executes 1 time/hour) 1. **Add conditional filters** Before: Automation: When machine state changes → Send notification (Executes on every state change, even Running → Running) After: Automation: When machine state changes AND new state = "Stopped" → Send notification (Executes only on Stopped state) 1. **Use machine triggers for eligible tasks** - If the task only updates machine state or activity fields, use a machine trigger (free) - Reserve automations for table writes, connector calls, and notifications ## Further reading - [Machine Monitoring](/r230/docs/machine-monitoring) - [How to Add and Configure Machines](/r230/docs/add-and-configure-machines) - [Machine Monitoring Architecture](/r230/docs/machine-monitoring-architecture) - [Build Your First MQTT Data Source](/r230/docs/build-your-first-mqtt-connector) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have solved a similar topic!
