title: "Machine Monitoring Solution Architecture"
slug: "machine-monitoring-solution-architecture"
status: "new"
updated: 2025-12-22T17:25:19Z
published: 2025-12-22T17:25:19Z
canonical: "support.tulip.co/machine-monitoring-solution-architecture"
> ## Documentation Index
> Fetch the complete documentation index at: https://support.tulip.co/llms.txt
> Use this file to discover all available pages before exploring further.
# Machine Monitoring Solution Architecture
Machine monitoring connects shop floor equipment to Tulip to track real-time machine data, calculate {{glossary.OEE}}, and build human-machine workflows. As you scale from monitoring a single machine to managing a fleet, **choosing the right architecture pattern is critical** for maintainability, cost-efficiency, and performance.
This guide synthesizes best practices from Tulip solution architects and customer implementations to help you design scalable, production-ready machine monitoring solutions.
**In this article, you will learn:**
- **Key concepts of machine monitoring components**
- **Decision tree for selecting the right machine monitoring architecture**
:::(Info) (Note)
This article is primarily intended for solution architects, IT/OT engineers, experienced citizen developers, and technical decision-makers evaluating machine monitoring implementations.
## Machine monitoring components
To understand architecture patterns, you need to know the core components of Tulip's machine monitoring system:
**Machine**: A digital representation of a physical asset. Machines have **attributes** (e.g., spindle speed, temperature) that you update via {{glossary.OPC UA}}, {{glossary.MQTT}}, or the [Tulip machine attributes API](/r230/docs/use-the-machine-attributes-api).
**Machine Type**: A template that defines states, attributes, and triggers for a category of similar machines (e.g., "CNC Mill" type for 5 different make/models).
**Machine Attribute**: A data point from a machine (e.g., "Cycle Time", "Part Count"). Attributes can be read-only (sensor data) or writable (setpoints).
**Machine Trigger**: Conditional logic that runs **headless** (without an app running) to update machine state or activity fields based on attribute changes.
**Machine Activity Table**: A system table that logs machine state history, part counts, defects, and downtime reasons for OEE calculation. **Important**: This table has no Tulip Table APIs enabling real-time reads & writes.
**Station**: A physical or logical location on the shop floor. You can assign machines to stations to enable "at this station" trigger logic.
### Typical enterprise-level machine connectivity architecture
The architecture below is the most common for enterprise-level large-scale connectivity.
![MQTT Setup v2.svg](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/MQTT%20Setup%20v2.svg){height="" width=""}
This shows how a shop floor machine would be connected to Tulip via an OT gateway with an MQTT broker, and optionally a {{glossary.DataOps}} platform.
## Select the right architecture
![Designing Machine Monitoring Solution.png](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Designing%20Machine%20Monitoring%20Solution(1).png){height="" width=""}
For more information, see:
* [Headless vs. app-based architecture](/r230/docs/machine-monitoring-headless-vs-app-based-architecture)
* [Machine monitoring app-based architecture patterns](/r230/docs/machine-monitoring-app-based-architecture-patterns)
## Related resources
Use the links below to find relevant resources for your machine monitoring solutions.
### Knowledge Base
- [Machine Monitoring](/r230/docs/machine-monitoring) - Foundational concepts and setup guide
- [How to Add and Configure Machines](/r230/docs/add-and-configure-machines) - Step-by-step machine configuration
- [Machine Monitoring Architecture](/r230/docs/machine-monitoring-architecture) - Network topology and IT infrastructure
- [Build Your First MQTT Data Source](/r230/docs/build-your-first-mqtt-connector) - Connector setup guide
- [Using Machine Data in Analytics](/r230/docs/machine-data-analysis) - Create OEE dashboards
- [Automations](/r230/docs/automations-1) - Automation capabilities
### Tulip Library
- [Machine Monitoring Dashboard App](https://library.tulip.co/apps/machine-monitoring-dashboard) - Pre-built dashboard template
- [Machine Monitoring Terminal App](https://library.tulip.co/apps/machine-monitoring-terminal) - Operator terminal with OEE tracking
- [Composable MES: Production Management Suite](https://library.tulip.co/suites/production-management) - End-to-end production apps
### Tulip University
- [Machine Monitoring Fundamentals](https://university.tulip.co/machine-monitoring-in-tulip)
- [How to Connect Machines to an OPC UA Server](https://university.tulip.co/how-to-connect-machines-to-an-opc-ua-server)
### API documentation
- [Use the machine attributes API](/r230/docs/use-the-machine-attributes-api) - Write machine attribute values
- [Table API guide](/r230/docs/table-api-guide) - Read and write Tulip Tables
{{snippet.Did you find what you were looking for}}
