--- title: "Machine monitoring data model" slug: "machine-monitoring-data-model" updated: 2025-12-22T17:23:23Z published: 2025-12-22T17:23:23Z canonical: "support.tulip.co/machine-monitoring-data-model" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Machine monitoring data model A common decision in machine monitoring is **when to use Tulip tables instead of the machine activity table**. **In this article, you will learn:** - **When to use Tulip tables** - **When to use the machine activity table** - **The strengths and limitations of each** ## Machine activity table: Built-in OEE tracking A system table that machine triggers automatically populate and that logs: - State (Running, Stopped, Offline) - Start time, end time, and duration - Downtime reason - Part count and defect count - Ideal run rate - Custom activity fields (user-defined) ### Strengths - Minimal configuration - automatically associated with Tulip machines - Optimized for OEE calculations (Availability, Performance, Quality) - Works seamlessly with machine triggers (headless) - Analytics can directly query machine activity data ### Limitations - **No Tulip Table API access** - you cannot programmatically read or write to the Machine Activity table via API - **No table record ID** - difficult to link to other tables - Export only via CSV archive (not real-time integration) ### Use machine activity table for OEE only If your **only goal** is to track machine uptime and downtime and calculate OEE, use machine triggers with the Machine Activity Table. This is the simplest, most cost-effective solution. #### Example ![Machine State by Value](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Machine%20State%20by%20Value.png) ## Tulip tables: Flexible data model for complex use cases ### When to use Tulip Tables - You need **custom data fields** not available in Machine Activity Table (for example, Work Order ID, Operator Badge, SKU) - You need **CRUD operations** (Create, Read, Update, Delete) via APIs - You integrate machine data with **other business processes** (quality, inventory, maintenance) - You want to **contextualize machine data** with work orders, batches, or production schedules ## Use both machine activity table and Tulip tables **Machine Activity Table** (via machine triggers): - Capture raw state changes - Calculate OEE metrics **Tulip Table** (via automations or app triggers): - Enrich machine data with business context - Enable API-based integrations - Link to work orders, quality records, and other data ### Example architecture Note: 'Automation' refers to Tulip [Automations](/r230/docs/automations). ![MM - Data Model for Downtime.png](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/MM%20-%20Data%20Model%20for%20Downtime.png) This hybrid model provides: - OEE dashboards from Machine Activity Table - Root cause analysis from Tulip Table with API access for external BI tools ## Handle manual data with rework and scrap patterns **Challenge**: Machines automatically report part counts, but human context (rework, scrap, manual adjustments) requires manual input. How do you reconcile automated machine counts with manual corrections? ### Avoid corrupting machine data **Do not** attempt to decrement machine part count when an operator logs rework. **Why this fails**: The machine does not understand human context. If you write back to the machine, you corrupt the raw data source. ### Separate truth sources 1. Let the machine report raw counts. 2. Use a separate table for manual adjustments. 3. Calculate net production via expressions. #### Example data model **Machine Activity Table** (automatic): - Part Count: 104 (raw machine output) - Defects: 0 (machine does not track) **Production Log Table** (Tulip Table, via app): - ID: 12345 - Work Order: WO-5678 - Machine ID: CNC-001 - Gross Parts: 104 (copied from machine at run end) - Rework Count: 4 (operator input) - Scrap Count: 0 - Net Parts: 100 (calculated: Gross - Rework - Scrap) - Timestamp #### App workflow: 1. Operator starts a run and selects a work order 2. Machine runs and increments part count automatically 3. Operator notices 4 parts need rework and passes them back through 4. Machine increments to 104 (the machine counts 104 parts) 5. Operator ends the run, and the app creates a Production Log record 6. App copies machine part count (104) to the Gross Parts field 7. Operator manually enters Rework Count: 4 8. App calculates Net Parts = 104 - 4 = 100 **Analytics**: - **Machine OEE**: Uses raw part count (104) for performance calculation - **Production Reports**: Uses Net Parts (100) for actual output **Optional enhancement**: Log defects to a Machine Activity Field for OEE Quality calculation: ![write rework count to machine attribute](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/write%20rework%20count%20to%20machine%20attribute.png) This allows OEE Quality % to reflect the actual defect rate while preserving raw machine counts. ## Further reading - [Create your first machine trigger](/r230/docs/create-your-first-machine-trigger) - [Automations](/r230/docs/automations-1) - [Tables](/r230/docs/tables) - [Export Tulip activity data](/r230/docs/export-tulip-activity-data) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have solved a similar topic! **OEE (Overall Equipment Effectiveness)** A key performance indicator (KPI) that measures manufacturing productivity by calculating the percentage of planned production time that is truly productive. **OEE** combines three factors: **Availability** (uptime), **Performance** (speed), and **Quality** (good parts produced). **Formula:** OEE = Availability × Performance × Quality **Scale:** Expressed as a percentage, where 100% represents perfect production (manufacturing only good parts, as fast as possible, with no downtime).
