--- title: "Light Kit technical specifications" slug: "light-kit-technical-specifications" tags: ["edge Connectivity", "Edge Device", "Factory Kit", "Light Kit", "Hardware"] updated: 2022-09-18T02:15:50Z published: 2022-09-18T02:15:50Z canonical: "support.tulip.co/light-kit-technical-specifications" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Light Kit technical specifications ## Tulip Light Kit Technical Specifications *Here are all the details about the Tulip Light Kit's technical specs.* ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Tulip%20Light%20Kit%20Technical%20Specifications_72756100.png) #### Voltage supply, Current Consumption and Conditioning - Rated supply voltage: 5V (Vin_min: 4.8V Vin_max: 5.5V) - Rated supply current: 4A (I_max is 0.4A per channel) - Nominal power consumption: 5W (2 LED strips fully illuminated) - IC: LTC4360 #### Temperature Range (Operating / Storage) - 0 - 75 ℃ #### Humidity - 5% - 80% rel hum. non-condensing #### OS/Software - Connect this device to a Tulip I/O Gateway - Configure the device using Tulip Apps #### LED Outputs - 8 Channel outputs - RGB Leds - LED IC: WS2812b #### Mechanical - 160mm x 100mm x 31mm (6.3 in x 4.0 in x 1.2 in) - Weight: 280g (0.62 lbs) - Aluminum (Anodized) - Mounting: 35mm DIN Mount Compatible
