Light Kit technical specifications
Tulip Light Kit Technical Specifications
Here are all the details about the Tulip Light Kit's technical specs.
Voltage supply, Current Consumption and Conditioning
  • Rated supply voltage: 5V (Vin_min: 4.8V Vin_max: 5.5V)
  • Rated supply current: 4A (I_max is 0.4A per channel)
  • Nominal power consumption: 5W (2 LED strips fully illuminated)
  • IC: LTC4360
Temperature Range (Operating / Storage)
  • 0 - 75 ℃
Humidity
  • 5% - 80% rel hum. non-condensing
OS/Software
  • Connect this device to a Tulip I/O Gateway
  • Configure the device using Tulip Apps
LED Outputs
  • 8 Channel outputs
  • RGB Leds
  • LED IC: WS2812b
Mechanical
  • 160mm x 100mm x 31mm (6.3 in x 4.0 in x 1.2 in)
  • Weight: 280g (0.62 lbs)
  • Aluminum (Anodized)
  • Mounting: 35mm DIN Mount Compatible
