--- title: "LIFX Unit Test (Wireless Lights)" slug: "lifx-unit-test-wireless-lights" tags: ["LIFX", "Unit Test", "Library", "Plugin"] updated: 2022-09-17T23:55:00Z published: 2022-09-17T23:55:00Z canonical: "support.tulip.co/lifx-unit-test-wireless-lights" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # LIFX Unit Test (Wireless Lights) ## LIFX Unit Test (Wireless Lights) *Use off-the-shelf WiFi lightbulbs with Tulip* **Purpose** The purpose of this article is to describe the steps required to integrate an LIFX light bulb with Tulip. **Video Overview of Application** [Embedded content](https://www.youtube.com/embed/PYf9gkLsNv4) **Setup Instructions** Setting up the LIFX light is the bulk of the setup. You will need to follow the instructions that come with your light to connect it to your WiFi network. Once connected, you will need to create an account with LIFX and get a "token". You can follow these instructions to get the token: [https://api.developer.lifx.com/docs/introduction](https://api.developer.lifx.com/docs/introduction) There are a few different types of authentication that can be used with this light. The Tulip unit test application relies on the Basic Authentication: the App token is passed in as the user name. After installing the application from the Library, navigate to the LIFX connector. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/LIFX%20Unit%20Test%20%28Wireless%20Lights%29_305129595.png) Click on the "production & testing & development" button and then click on "edit headers" ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/LIFX%20Unit%20Test%20%28Wireless%20Lights%29_305130460.png) Finally, replace "YOUR TOKEN HERE" with your token. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/LIFX%20Unit%20Test%20%28Wireless%20Lights%29_305131021.png) Your application is now set up! When you load the unit test application you will see a list of your devices (lights). Clicking on one will let you change its color.
