--- title: "Set up wireless connection on Edge IO" slug: "how-to-set-up-wireless-connection-on-edge-io" tags: ["Edge IO", "Edge", "edge Connectivity", "Edge Device"] updated: 2022-09-30T17:18:05Z published: 2022-09-30T17:18:05Z canonical: "support.tulip.co/how-to-set-up-wireless-connection-on-edge-io" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Set up wireless connection on Edge IO ## How to Set Up Wireless Connection on Edge IO *Enable WiFi on Edge IO* To set up a wireless-only connection on Edge IO, make sure you have first [set up your hardware](https://support.tulip.co/docs/setting-up-an-edge-io) First, log into the Configuration page on your Edge IO’s Device Portal. You can either access this portal by: - Connecting to the Edge IO access point (wifi network `TULIP-{EIO_SERIAL_NUMBER}`) and navigating to [http://10.0.3.1](http://10.0.3.1/) - If the Edge IO has a temporary wired connection, you can instead navigate to `http://{EIO_IP}` while on the same network as the Edge IO From here, you can collapse the Wired connection tab, or scroll down to the Wireless Connection tab. ![Edge IO Wireless Network Connection](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Set%20Up%20Wireless%20Connection%20on%20Edge%20IO_232264801.png) Ensure that the WiFi is set to enabled, then select your network from the dropdown. Upon selection, you will be prompted to fill out the network's password. It will look something like this. ![Edge IO Wireless Network Credentials](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Set%20Up%20Wireless%20Connection%20on%20Edge%20IO_232265240.png) At the bottom of the page, press Save. You may get disconnected from the Access Point when the network settings change; if this is the case, then reconnect to the Access Point network when it reappears. ![Edge IO Wireless Connection Enabled](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/How%20to%20Set%20Up%20Wireless%20Connection%20on%20Edge%20IO_232267287.png) Once saved, the circle next to the Wireless dropdown should become green after recognizing the network. Now your Edge IO can run entirely over WiFi, and will not require a wired connection. --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have faced a similar question! **Edge IO** **Edge IO** is a Tulip-developed **Edge Device**. Interface with digital inputs directly from **Triggers**, flip digital outputs, run **Node-RED** flows, and more! **Edge IO** can also act as a **Connector Host** or OPC-UA Broker **Device Portal** The **Device Portal** is the home where you can configure **Light Kits** and Edge Drivers, see **Edge Device** network status, and more.
