--- title: "Edge MC technical specifications" slug: "edge-mc-technical-specifications" tags: ["Edge", "Edge MC", "edge Connectivity", "Edge Device", "Hardware"] updated: 2025-09-08T20:52:47Z published: 2025-09-08T20:52:47Z canonical: "support.tulip.co/edge-mc-technical-specifications" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Edge MC technical specifications ## Technical Specifications for Edge MC *Edge MCProduct Specifications* ### Dimensions - 63mm x 56mm x 35mm ### Weight - 10g ### Power - 5V / 2.5A USB Micro, 120V/240V (MFG P/N: SMI10-5-V-I38 included) ### Processor - CPU: Allwinner H3 SoC (Quad A7) - Storage: 8GB eMMC - RAM: 1GB ### RTC + battery ### 2048 byte PROM ### **Software** - Tulip Firmware - Node-RED ### Peripherals - 2x USB 2.0 ### Networking - 1x 1GB/s Ethernet Phy WAN - 1x 10/100 MB/s Ethernet Phy LAN - Dual Band 802.11 b/g/n Wireless (supports concurrent AP/Station modes) - LAN IP Range - 10.0.5.0/24 ### Legacy - 1x 5V TTL UART with TX/RX (no RTS/CTS) ### LEDS - 2x Green LEDs - 1x Red LEDs - 4x Link + Speed LEDs for 2x Ethernet ### Trackable Assets - QR Code based serial “tulip-mfg://EMC-01-XXXXXXXX” - MAC addresses ### Certifications - FCC - CE - CE-RED ### DHCP Addresses - For dynamic addresses, 10.0.5.2-10.0.5.20 are available. - For static addresses, the entire 10.0.5.0/24 subnet is available which is 10.0.5.21-10.0.5.254. **Edge IO** **Edge MC** is a Tulip-developed **Edge Device**. run **Node-RED** flows on dedicated hardware with built-in security and stability. **Edge Mc** can also act as a **Connector Host** or OPC-UA Broker
