--- title: "Edge IO technical specifications" slug: "edge-io-technical-specifications" tags: ["Edge", "Edge IO", "Hardware", "Triggers", "edge Connectivity", "Edge Device"] updated: 2025-06-23T14:25:50Z published: 2025-06-23T14:25:50Z canonical: "support.tulip.co/edge-io-technical-specifications" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Technical Specifications for Edge IO ## Technical Specifications for Edge IO *Documentation for the Edge IO technical specifications* **Certifications** - FCC, CE, TELEC, and SRRC **Dimensions** - 150mm x 130mm x 35mm **Weight** - 250g **Power** - 24V 2 Terminal, Non-locking Phoenix Contact Connector **Processor** - ARMv8 4x A53 core - 8GB eMMC - 2 GB DDR3 RAM **RTC + Battery** **USB-OTG “Type B” plug** **Temperature Range (Operating / Storage)** - 0 - 75 ℃ non-condensing **Software** - Tulip Firmware - Node-RED **Industrial I/O** - 4x 24V relay output drivers up to 500mA - 8x Industrial I/O for 5V to 36V digital input **Sensors and Instrumentation** - 24V IEPE current source and input - -3V - 3V Differential Input - 0 - 10V Input - Optional: 24V power source **Peripherals** - 6x USB 2.0 - 1x 2-channel integrated Tulip Light Kit engine **Legacy** - 1x RS232 with RTS/CTS - 1x RS485 half-duplex **Networking** - 1x Gigabit Ethernet Phy (native) WAN - 1x 10/100 Ethernet Phy LAN - Dualband 802.11 ac Wireless Internet - LAN IP Range - 10.0.5.0/24 **Security** - ATECC608A **Trackable Assets** - QR Code-based serial “tulip-mfg://EIO-01-XXXXXXXX” - Globally Unique MAC Addresses **DHCP Addresses** - For dynamic addresses, 10.0.5.2-10.0.5.20 are available. - For static addresses, the entire 10.0.5.0/24 subnet is available which is 10.0.5.21-10.0.5.254. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Technical%20Specifications%20for%20Edge%20IO_417049728.png) --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have faced a similar question!
