--- title: "Edge Device Functionality" slug: "edge-device-use-cases" type: "index" canonical: "support.tulip.co/edge-device-use-cases" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Edge Device Use Cases 12 articles ## [Use Edge Devices as a machine data source](https://support.tulip.co/docs/use-edge-devices-as-a-machine-data-source.md) Updated on 2022-12-13 Learn more about using Tulip Edge Devices as a native Machine Data Source in Tulip As of OS50, Tulip Edge Devices can now be used natively in Tulip as a Machine Data Source. In this article, we... ## [Edge Devices and FlowFuse](https://support.tulip.co/docs/edge-devices-and-flowfuse.md) Published on 2024-03-25 With the release of OS 57, FlowFuse is available as a module within Edge IOs and MCs. Setting up FlowFuse on your Edge Device If you haven't already set up your Edge IO or Edge MC , please check out... ## [Set up the Edge Device MQTT broker](https://support.tulip.co/docs/set-up-the-edge-device-mqtt-broker.md) Updated on 2024-12-04 | Published on 2022-09-13 Purpose Learn how to set up an external MQTT broker on Tulip Edge Devices Beginning with OS 50.1, Tulip Edge Devices have an external MQTT broker to which client devices can connect. Instructions Log... ## [Set up an MQTT bridge on an Edge Device](https://support.tulip.co/docs/set-up-an-mqtt-bridge-on-an-edge-device.md) Updated on 2024-07-15 | Published on 2024-07-15 How to: Set up an MQTT Bridge A setup guide on using Edge Device to read MQTT MQTT Broker Beginning with OS58, this functionality will be available for Edge devices. In this article, you will learn... ## [Use Edge MC to run OPC UA](https://support.tulip.co/docs/using-edge-mc-to-run-opc-ua-1.md) Updated on 2022-09-20 Using Edge MC to Run OPC UA Run your OPC UA server on an Edge MC host. If you are using an OPC UA data source, you may want to pull that information into Tulip to utilize in apps. While Kepware and... ## [How to use GPIO on Edge IO](https://support.tulip.co/docs/use-gpio-on-edge-io.md) Updated on 2023-08-05 How to use GPIO on Edge IO Guide to reading digital inputs and writing digital outputs on Edge IO In this article, you will learn how to read digital inputs and write digital outputs on Edge IO.... ## [Use Node-RED with Edge MC](https://support.tulip.co/docs/use-node-red-with-edge-mc.md) Updated on 2024-03-25 Using Node-RED with Edge MC Instructions on how to get started with Node-RED on an Edge MC See here for using FlowFuse and Node-Red on an Edge MC Node-RED is a visual, flow-based programming tool to... ## [Use Node-RED with Edge IO](https://support.tulip.co/docs/use-node-red-with-edge-io.md) Updated on 2024-03-25 Using Node-RED with Edge IO Instruction on how to get started with Node-RED on an Edge IO See here for using FlowFuse and Node-Red on an Edge IO Node-RED is a visual, flow-based programming tool to... ## [Use Serial with Edge IO](https://support.tulip.co/docs/how-to-use-serial-with-edge-io-1.md) Updated on 2022-09-30 How to: Use Serial with Edge IO A setup guide on using Serial with Edge IO In this article, you will learn the technical details of using serial on Edge IO. Edge IO supports serial connections over... ## [Use edge devices to run on prem connector host](https://support.tulip.co/docs/using-edge-io-to-run-opc-ua-1.md) Updated on 2024-07-15 Run your On Prem Connector Host on an Edge IO. The On-Prem Connector Host is a service that lives within your network that proxies trafic to the Tulip cloud for data that is not accessible to the... ## [Communicate with Machines using Edge MC's Connector Host and Node-RED](https://support.tulip.co/docs/communicate-with-machines-using-edge-mcs-connector-host-amp-node-red-2.md) Updated on 2025-12-02 Learn how to use Edge MC's Connector Host to communicate with Node-RED devices In the following article we will... Set-up your Edge MC's Connector Host Build a Connector Function to communicate with... ## [Tulip and IoT guide](https://support.tulip.co/docs/tulip-and-iot-guide.md) Updated on 2022-11-17 | Published on 2022-09-13 Here's an overview of the different types of devices that you can integrate into Tulip. Tulip supports a variety of IoT enabled devices that can help you achieve common manufacturing tasks, such as:...
