--- title: "Configure SNMP settings for Edge Devices" slug: "configure-snmp-settings-for-edge-devices" updated: 2023-09-07T18:46:48Z published: 2023-09-07T18:46:48Z canonical: "support.tulip.co/configure-snmp-settings-for-edge-devices" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Configure SNMP settings for Edge Devices *Learn how to configure SNMP settings for Tulip's Edge Devices* Beginning with OS 50.1, Tulip Edge Devices include an SNMP daemon for IT personnel to monitor the device on their network. Due to the large number of tools for interacting with SNMP devices, this article will not cover them all. If you would like to assist in expanding this document by providing necessary information and screenshots, please contact [support@tulip.co](mailto:support@tulip.co). ## Turn On SNMP To turn on SNMP availability, navigate to the Device Portal dashboard for the specific Edge Device you want to enable it for. On the right hand side, there are a series of toggles. Click on the **SNMP** toggle button to enable the service. ![SNMP Service Toggle](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/SNMP%20Service%20Toggle.png) ## SNMP Settings All of Tulip's Edge Devices share a common SNMP configuration. The devices implement SNMPv3 with a read-only and authpriv `tulip` user. Below is an example configuration for the `net-snmp` Linux utility: ``` #################################################################################################################### ## ## snmp.conf ## ## - created by the snmpconf configuration program ## #################################################################################################################### ## SECTION: Default Authentication Options ## ## This section defines the default authentication ## information. Setting these up properly in your ## ~/.snmp/snmp.conf file will greatly reduce the amount of ## command line arguments you need to type (especially for snmpv3). ## defaultport: The default port number to use ## This token specifies the default port number you want packets to ## be sent to and received from. ## override: with -p on the command line. ## arguments: portnum defaultport 161 ## defversion: The default snmp version number to use. ## override: with -v on the command line. ## arguments: 1|2c|3 defversion 3 ## defsecurityname: The default snmpv3 security name to use when using snmpv3 ## override: with -u on the command line. ## arguments: securityname defsecurityname tulip ## defsecuritylevel: The default snmpv3 security level to use ## override: with -l on the command line. ## arguments: noAuthNoPriv|authNoPriv|authPriv defsecuritylevel authPriv ## defauthtype: The default snmpv3 authentication type name to use ## override: with -a on the command line. ## arguments: authtype defauthtype MD5 ## defauthpassphrase: The default snmpv3 authentication pass phrase to use ## Note: It must be at least 8 characters long. ## override: with -A on the command line. ## arguments: passphrase defauthpassphrase tulip-snmp ## defprivpassphrase: The default snmpv3 privacy pass phrase to use ## Note: It must be at least 8 characters long. ## override: with -X on the command line. ## arguments: passphrase defprivpassphrase tulip-snmp #################################################################################################################### ## SECTION: Debugging output options ## ## This section allows debugging output of various kinds to ## be turned on or off. ## dodebugging: Turns debugging output on or off (0|1) ## arguments: (0|1) dodebugging 0 ``` #### Details - Version: `3` - User: `tulip` - Security Level: `AuthPriv` - Auth Passphrase: `tulip-snmp` - Auth Type: `MD5` - Priv Passphrase: `tulip-snmp` - Priv Type: `DES` - Port: `161` --- Did you find what you were looking for? You can also head to [community.tulip.co](https://community.tulip.co/?utm_source=intercom&utm_medium=article-link&utm_campaign=all) to post your question or see if others have faced a similar question! **Edge Devices** **Edge Devices** are any hardware intended to connect physical things to the cloud. This can include entirely mechanical devices, older machines without network functionality, PLCs, and more. Tulip sells the **Edge IO** and **Edge MC** that interface directly into **Triggers** in a breeze, but Tulip can also support other Edge Devices.
