--- title: "Communicate with Machines using Edge MC's Connector Host & Node-RED" slug: "communicate-with-machines-using-edge-mcs-connector-host-amp-node-red-2" tags: ["Communication", "Machine", "Edge MC", "Connector Host", "Node-RED"] updated: 2025-12-02T15:57:30Z published: 2025-12-02T15:57:30Z canonical: "support.tulip.co/communicate-with-machines-using-edge-mcs-connector-host-amp-node-red-2" --- > ## Documentation Index > Fetch the complete documentation index at: https://support.tulip.co/llms.txt > Use this file to discover all available pages before exploring further. # Communicate with Machines using Edge MC's Connector Host and Node-RED *Learn how to use Edge MC's Connector Host to communicate with Node-RED devices* **In the following article we will...** - Set-up your Edge MC's Connector Host - Build a Connector Function to communicate with your device - Build an app to communicate with your device **Prerequisites** - Please make sure you've enabled Node-RED on your Edge MC. For instructions on how to do so, see [this](https://support.tulip.co/docs/using-node-red-with-edge-mc) article. ## Summary By leveraging your Edge MC's Connector Host, you can use an App to trigger Connector Functions that communicate with Node-RED running on a Tulip Device. This will ultimately give you the ability to write to machines from a Tulip app. ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_314676359.png) ## Setting up your Edge MC Connector Note: If you're not familiar with Connectors and Connector Function in Tulip, check out [this](https://support.tulip.co/docs/what-are-connectors) article. To get started, first navigate to your **Connectors** page, and click **Create Connector**. A modal will appear, prompting you to fill in the following information: - **Name**: Choose a name for your Connector - **Description**: Choose a name for your Connector - **Connector Type:** Select **HTTP** Next, you will need to specify the Connector's details. Click on the **production & testing & development** button to open the **Edit Connector Details** modal, and enter the following information: - **Running On**: Select your **EMC Connector Host** Note: In the event that you don't see this, navigate to your Edge MC portal and make sure **Connector Host** has been enabled. - **Host:** Enter **localhost** - **Port**: Enter **1880** (this is the port Node-RED is running on) - **TLS**: Enter **No** There is no need to add headers or certs. Now you're reading to click **Test**, and verify your connection is passes. Finally, click **Save**. ## Creating a Connector Function Now that you've successfully set-up your Connector, you're ready to start building connector functions to communicate with your Tulip devices. In this example Node-RED will act as a HTTP server. To set-up your connector function you will need to configure the function in Tulip, as well as in your Node-RED editor. In this example, we will be building a simple function that takes the input of **firstName** and **lastName**, and returns a response of "Hello **firstName lastName**!", as well as a timestamp. #### Building the Connector Function in Tulip Navigate to the Connector for your Edge MC, and select **Create Function** in the top right corner. Select **GET** as the Request Type, and enter the endpoint: **/helloWorld**. While this may feel arbitrary, in a later step we will configure this endpoint in the Node-RED editor: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313562844.png) Configure the inputs of the function to include **First Name** and **Last Name:** ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313565744.png) In the Request Body, select Content Type: **JSON**, and set the following keys for the inputs. These will be referenced later in the Node-RED editor: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313566597.png) Now add the following outputs to the Connector Function, **Message** and **Time**. Add the associated Body to the outputs, so they can referenced in the Node-RED editor: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313566172.png) Next, verify that your **Response Type** is set to be **JSON.** You've now finished configuring the Connector Function on the Tulip side. Click **Save**, to save the connector function. #### Building the flow in Node-RED It's now time to open the Node-RED editor from your Edge MC portal, and set-up a new flow. First, drag and drop a **http in** **node** from the network section, into your editor. Set the node to have the following configuration: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313568450.png) It's important that the **Request Method** and **Request URL** match the connector function you configured in Tulip. Next, drag and drop a **change node** with the following configuration: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313569078.png) Set msg.payload to be **JSON**, and leave it as an empty object: {} Now insert a **template node**. This is where you can take properties of the incoming message (connector function inputs), and build a string with them (e.g. "Hello World"). ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313569613.png) ``` Hello, ##{{req.body.firstName}} ##{{req.body.lastName}}! ``` Now it's time to add another **change node**, to capture a timestamp, and send it back as part of the response. Configure the node like the following: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313570022.png) At this point our flow has accepted the inputs being sent from Tulip, and it's now time to configure a response. To do this, drag and drop a **http response** **node**. Configure the response to have a **Status Code** of **200**, **OK**: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313570331.png) The overall flow is now finished, and should look something similar to the following: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313570517.png) Please note the green nodes in the above flow are **debug** nodes, utilized to show your payload in the Node-RED editor. The final step will be to **Deploy** your flow from the Node-RED editor. You will now be able to Test you connector function from the Tulip test environment, #### Running the Connector Function through an App Now that you've set up your connector, and a connector function that effectively communicates to your device using Node-RED as an http server, you're ready to integrate this functionality into your apps. In this example, there are two input boxes to accept the **firstName** and **lastName** variables that will be sent in our request: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313571948.png) In the button "Say Hello!", enter the following trigger to call the connector function: ![](https://cdn.document360.io/7c6ff534-cad3-4fc8-9583-912c4016362f/Images/Documentation/Communicate%20with%20Machines%20using%20Edge%20MC%27s%20Connector%20Host%20%26%20Node-RED_313570870.png) Once you've entered your inputs, and clicked "Say Hello!" you will have effectively sent an http request to your Tulip device, and received a JSON response. To test your app, click on the **Test** button in your App Editor to enter Development Mode!
